Jarvdog
- Oct 26, 2012
- 9
This is my first post to eng-tips, so if you have any tips about forum posting, I will take them into consideration next post. I would like to state that I am relatively inexperienced in the civil engineering world. I just received my B.S. in CE in May of 2011 and have been soaking in as much knowledge and experience I can at work. I have modeled a few bridges and culverts in hec-ras over the last year and a half, however I know I really haven't even scratched the surface. Please keep this in mind. Any recommendations or suggestions would be helpful.
I am currently modeling an existing private bridge on a windy stream in a flat, wide, flood plain with a low flow of 400cfs. A few hundred feet upstream of the structure, the stream turns and runs parallel with the road until it gets to the bridge, where it turns again to flow underneath it. I created the geometry in microstation and imported it into hec-ras. I created cross sections perpendicular to the stream. Once I ran the model with a Q100 of 1750cfs, it quickly became apparent that it the stream over tops the road for a few hundred feet and the original winding low flow stream alignment is no longer applicable.
Assuming that the flood plain is flooded and is now using the road as a weir, in addition to the bridge, my flow path goes from parallel to perpendicular to the road. So now I need to create a new stream alignment, bank/over bank location, and cross section locations. I'm assuming my cross sections will need to be parallel with the road and bridge. Is there a way to make nonlinear x-secs in hec? Another issue is placing my channel bank locations and over bank locations on the new cross sections. The low flow situation locations of the banks is obvious, however once the channel width becomes the width of the entire flood plain, it becomes unclear. The same goes with the stream alignment location for the very same reasons. I'm hoping this is a common situation.
I hope I was able to describe the issues and circumstances well enough here. The hydraulic engineer on staff is currently out of office and cannot be reached, so I would greatly appreciate any recommendations.
Thanks,
Ryan
Thanks,
Ryan
