Height Alert Barrier
dik
25,996
I have a project with a 24'x16' high HSS portal... likely 6x6 verticals and 5x8 horizontal. Its only purpose is to support a 'plank' allowing a 13'6" vehicle to pass underneath... The portal will support a 'plank' that will be supported at 1/5 points... spans 5', 15', and 5' (approx). Do you know of an easy way to determine if a 2x8 PSL will span 15' with 5' (approx) cantilevers and not buckle?
Almost no load, other than the PSL plank.
Dik
So9metims these so called vehicle height limit things are made so the actual limit thing hangs on a more sturdy beam thing. This allows an over height vehicle to hit the lower easily moved limit thing , yet does not knock the whole device down. The lower "thing" can be a pole hung on cables or chains from the higher solid "beam thing" you are designing..
1) could do it as a true lifting beam problem if you feel fancy.
2) could use woodworks, forte, etc to model a double cantilever with rotational supports at the hangers (not quite true).
3) could use one of the two models shown below which are even less true.
Technically, neither #2 nor #3 is truly correct but, for something with near zero consequences, I'd consider any of these good enough. Or you could just go with a 3.5" wide piece and think on it no more.
KootK has it... but forces in opposite direction W/2 are the hanger loads... I think I'll contact a PSL supplier to see what they think... I don't think it's a problem... just want to know for sure... and yes, it's moveable so if a vehicle comes in contact with it, it will move... not break.
OG... it hangs from the portal frame.
For something like this I think my analysis would consist of "I've picked up a 20ft(25ft...a long board) 2x8 before, in the middle, and it didnt do anything but bend a little bit, even when bending weak axis." Not going to buckle, unless a group of hooligans comes by and hangs on it.
What's the attachment to the cable? Might go beefier on the headache bar to get a more durable connection.
Your hanger (a chain, I guess) will have more chance to be damaged than the beam, as it suffers dynamic (impact) force in a random manner. I think the supplier will have some suggestions.
Thanks retired13... I was thinking of a cable with closed loops, but a chain with open eyes might work better.
Dik
I'd put the hangers on an angle to resist lateral movement.
Dik
It warrants a dynamic analysis :) Joking aside, I have seen V shape hanging chains. You may chose more flexible chains that will break with a run over truck, instead of the entire frame been pulled with it. I am overthinking here, but replace a chain is much cheaper than the frame, isn't it?
Something to remember...
Dik
Don't use a PSL outside. Use regular PT lumber, or something else. Regular PSL/LVL/LSL and wet exposure with a critical single through bolt connection isn't a great long term element. Even though they make a PSL-PLUS that is good for exterior, i have reservations but maybe could be sold on that product. Also, i'd recommend through bolts vs lags, personal preference :)
Yes... not exposed to the elements... but no PWF treatment... thanks... bolts maybe a better idea...
Dik
