Has anyone heard of or seen the phenomena where the base circle diameter of an involute helical gear is larger than the root diameter??? I am running into this an can't determine if it is a problem or not.
See attached screenshot of the beginning of a model for a helical gear in PRO-E. Shown is a Base Circle Diameter (large blue diameter), the root diameter (small blue diameter), and the involute curves for the tooth profile. Notice how the involute curves are do not extend to the small diameter blue circle. That is because my calculations are setting the base circle diameter (where the involute tooth profile is to be derived from) larger than the root diameter.......????????
Ryan
Ryan
