engineer2385
If Helium seat leak test is required by a customer for a swing check valve, what should govern test duration and the leakage criteria? Gas Pressure for seat test is 80 Psi minimum as per SP-61. MSS-SP-61 gives leakage rates for seat leak tests with Air and Gas. Does that mean it includes Helium?
