Helix Angle relative to Pitch of a Spiral 1
williedawg
152
I know this is easier than what I'm making it....
When constructing a Spiral and the starting position is known, what is the PITCH value you'd enter to get
a common 45deg tooth gear such as for a matched set of right-angle gears.
Tried 8, which doesnt look too bad, but I know it's gotta be something definite.
The gear blank is 1.942 dia; How is the PITCH value arrived at?
after some deliberation, it dawned on me that the value for PITCH is the blank O.D. x Pi for a 45deg tooth. (1 to 1 ratio)... unless I'm missing something.
