Hello all,
I work as an application engineer and I have recently taken over a project regarding the construction of gears in general. So I have only a basic understanding of the subject.
I noticed that in the CAD construction the person who was previously responsible of gears has defined more than just one helix angle, i.e. one for each circle: a helix angle for the tip diameter, base diameter and root diameter.
In the actual construction we use only the helix angle at the root diameter (formula = 180/π*rtan(rootØ/referenceØ)*tanß), while in all the other formulas we use the "regular" ß=20° angle. This helix angle at the root diameter actually determines the path of cutting away material from a cylinder with a diameter = the tip diameter (the path of the tool with which we would obtain the gear).
I have read a bit through DIN 3960, but was unable to find a simple explanation of why it is important to use different ß angles.
Can anyone explain as simple as possible the necessity (if there is a real one) of having a different ß angle for each defining circle?
Thank you in advance.
