Helix that gets less tight as it spirals in toward center.
plutoniumsalmon
Industrial
Oct 26, 2019
9
Hello.
I was wondering if someone could talk me through creating a spiral that gets less tight as it moves towards the center. I want to create a part where a ball endmill would progressively go down in z towards the center as it spirals in while maintaining the same spacing in the cusps between its passes. For this I need to create spiral that grows. Thank you
If you can write an equation to describe the path, that equation can be used to define what they call a 'Law Curve', that is a curve driven by a formula. So, look for 'Law Curves'.
John R. Baker, P.E. (ret)
Irvine, CA
Siemens PLM:
The equation is going to be a problem. I am terrible at this. I will try
You can try the Helix command first, it might cover some basic cases (such as linear size and cubic pitch rules) without needing to resort to a formula.
NX has "Trochoidal cutting", doesn't this do what you are looking for ?
Else, can you explain in detail how that helix should be ?
should it be conical and vary in pitch ?
I think ? this is the engage we are talking about ?
Tomas
The more you know about a subject, the more you know how little you know about that subject.
