Nahid Mubin
- Mar 24, 2023
- 16
In siemens NX's center constraint, I can set two faces of a body two be in the center of two faces of another body. But these constraints only work if the faces are all parallel. You can check my previous thread here to understand the issue- https://www.eng-tips.com/threads/center-constraint.513106/
Now I want that this constraint should also work incase the faces are symmetric even if not parallel. How can I add this option using NXOpen python API?
