Hello, good time I want to convert 3
Alinpsh
Petroleum
Oct 7, 2024
1
Hello, good time I want to convert 30% hydrochloric acid in industrial dimensions to 37% concentration in laboratory grade I wanted to see how I can get the process description and thermodynamic data extraction and process map Thank you for helping me
Do you want the plant layout, isometrics, controls software setup, and fully trained operators supplied as well?
Eng-tips isn't a place for free design and for others to do your job for you. Get out of here.
One way may be to absorb hydrogen chloride gas into 30% HCL in a packed bed absorber column under slight pressure, since HCL gas is quite soluble in water. See Fig 2-11 for enthalpy - concentration data and table 2-10 for vapor pressure of HCl vapor over HCL solutions in the 7th edn of Perry Chem Engg Handbook. With some effort, if you are a chemical engineer, you can work up dimensions for this packed bed.
