selvakumardc
- Apr 25, 2014
- 1
Hello
I have a steam duct shell of 3.2 m diameter and I will have to weld a opening of 2 m diamter and this nozzle opening is directly fouling with my 3.2 dia shell Circumfrential weld joint. I am aware the ASME Sec Viii allows the nozzle in the joint but being this large opening I want to know the design and NDT requirements. I have limitations like cannot perform RT but UT is possible to all extent both inside and outside of shell. The shell is 16 mm thick and same is the opening. No RF pad used.design pressure and temperatures are 1.5 barg, 120 Deg C also full vacuum. Please advise am I allow to cut the CS joint of shell and open for 2m opening. 3.2 m shell has no RT or UT performed which is designed for Nil category.
