Hello, I need to split one flow
Biza
Student
Jul 31, 2019
4
I need to split one flow into different lines,is it possible to have the same flow in every pipe without using a flow control valve for the different lines, Is it enough to ensure the same diameter and the same length to have an equal distribution of the gas?
Thank you
In theory yes, in real life maybe.
How similar do the flows need to be? Is there any difference in the intake and exhaust arrangements of the pipes?
Cheers
Greg Locock
