Hello, I'm looking at using slag c
clayR
Geotechnical
Nov 26, 2002
30
I'm looking at using slag cement and portland blend stabilized with bentonite for the purpose of backfilling an abondoned utility.
What is the best ratio between slag/portland?
My mix water will be at about 6% bentonite by wt of water, and I'm thinking a 2:1 water/slag+portland should give the 200 psi at 56 days? Does anyone have experience with a mix like this? clay
I would suggest you put sand in this mix as well. Using bentonite, portland cement, and ground blast furnace slag (GBFS)cement in a water slurry will result in high shrinkage on curing. I would suggest a 10% bentonite, 5% cement (50/50 blend), 85% sand mix with enough water to give placement consistency.
Ron,
Thanks for the reply, yes sand will reduce shrinkage but will also reduce my ability to pump any great distance. I want to pump 2,000 ft +/-. I think I can live with the shrinkage with the addition of post grout pipes fixed to the top of the box. I currently have mixes being tested to confirm 200 psi. Will keep you posted on the results. clay
