Hello, I'm looking to get a rule
PrazSparty
Automotive
I'm looking to get a rule to add two parameters together when an "if" command is used in a rule.
If the `Width Offset Needed` = "RH" or "LH" then I need the `Name/Stock Size` parameter to update to include the added length of the `Width Offset Length`.
In other words, if the offset is needed then the size should update to 32 because 22mm from the `Angle Length` plus the 10mm from the 'Width Offset Length`
I've tried multiple strings like below with no luck.
if `Width Offset Needed` =="RH"
`Angle Length` = ToString(`Angle Length` +`Width Offset Length`)
your "Angle Length" is a length parameter, ToString as the name implies makes a STRING of a real value.
Try `Angle Length` = `Angle Length` +`Width Offset Length`
regards,
LWolf
Thanks LWolf, I did try that and i get a weird number like 0.0074
you could try something like this:
if ( Width Offset Needed` =="RH" or `Width Offset Needed` =="LH")
`Total Angle Length` = `Angle Length` +`Width Offset Length`
else
works for me
Eric N.
Thanks for the feedback, i will give it a try.
Would you happen to know how to hide/deactivate 3D text using a rule? I have tried both ways as shown below with no luck.
if `Pin Style` == "Round Slot"
`Annotation Set.1\Hole Size\Activity` = false
if `Pin Style` == "Round"
`Annotation Set.1\Slot Size` .Show = false
