DaPinci
- Mar 26, 2022
- 3
I am designing a cutting device to cut a threaded wire (M1.4x0.3) via counter-torque (torque applied to a nut, causes the wire to fail in tension).
ISO 965-1 states that normal engagement length is 0.7 < l < 2mm and long engagement would be anything over 2mm. The current design for the cutter internal thread is 5mm long for various reasons.
ISO 965-1 states that for long engagement threads it is better to use grades 6 or above.
ISO 965-1 also states that for M1.4 and smaller the combinations 5H/6h, 4H/6h or finer shall be chosen.
So in this instance, M1.4 with long engagement, what is the ideal thread fit?
Additionally, my manufacturer is telling me they can only get a hold of a 6H/6g machine tap. Will 6H/6g work or should I try to use 4H/6h per ISO?
Am I fretting unnecessarily? If you can recommend any textbooks or other relevant sources of information, I would appreciate it.
