Help!!!!! I Cannot start the Setup???????
MichaelDenmark
5
I have been using Pro Engineer2001 on Windows XP without any problems. Now that I have installed Windows2000(pro) I cannot start the installation :-( . When I click on the Setup-Icon nothing happend???. (It´s the same CD).
Can anyone help??
Michael
what is the exact name (label) of your pro-e cd ?
Be sure that you read the installation directions carefully and follow them to the letter. System configurations are different for "NT, 2000 and XP Pro than the standard Windows installation. You may have to make some setting adjustments before the program installs. Also, the path to the program has to be as stated, in the instructions or set-up will not start.
Live Aloha
Frank M.
Tradewind Resources
Thanks for the respons. In the meantime I have solved the problem and for others with same symtoms read this: . This describe what filesystem (fat32, ntfs and so on) you have to use accoding to the operating system on your PC. My problem was that I where using XP with Fat32 when I should be using Ntfs.
MichaelDenmark
