I'm a mechanical engineer but I have no hydraulic experience. I'm trying to find the right pump to design into a machine I'm working on. The machine would be powered by a variable displacement pump directly coupled to a 28 hp Kohler (or similar) engine. After wading through an endless assortment of online info over the last 6 weeks or so I'm dazed and glazed but I've still not found what I need. My wish list is shown below. The closest I've found to matching my needs is a Sauer-Danfoss "L" or Sauer-Danfoss series 45 pump, but these still don't do it all for my application. Can someone please get me pointed toward the right pump?
* 1-1.5 in^3/rev (16-25 cc/rev).
* ~600 - 3600 RPM
* SAE "A" or "B" mounting to motor.
* 3000 psi continuous rating.
* No charge pump needed (open circuit).
* Capable of pumping both directions (fixed shaft rotation direction)
* Swash plate control by stepper motor or external mechanical connection which I can add my control to.
* Prefer if all porting is on back plate (I'll be taking off the back and directly connecting to a custom manifold)
* Available individually (non-oem).
* Reasonably priced (I see mowing machine pumps at ~$300 and industrial stuff $1500 & up. My comfortable budget is $800/ea. in small quantities)
Pumps that I've found that are close to what I'm looking for (but not quite):
Sauer-Danfoss Series L (size 15 or 23)
Sauer-Danfoss Series 45 (L25C):
Mark
* ~600 - 3600 RPM
Mark
