I have been tasked with designing a ramp, and I have strict criteria that I have to meet. Due to these criteria, I don't believe that I can achieve this design with conventional sheetmetal or metal construction and think only a composite structure will work.
The ramp is 33.75W x 23.63L, with a max thickness of .50 inches. The ramp will see a max load of 770lbs in the form of a wheelbarrel/wheelbarrow. I am not allowed to have any supporting structure, except at the top of the ramp where it will be hinged with a piano hinge. This allows the ramp to be folded away. The environment will be outdoors, where it can be subjected to Arizona heat, Florida humidity, Wisconsin winters and everything inbetween. Oh, and I forgot to mention that it can't weigh more than 25lbs...
Since I know the material Unobtainium doesn't exsist, I am hoping someone from this forum may be able to point me in the proper direction in what types of composite materials I should be looking into. This would include a realistic thickness (I'm thinking 1.00" min) and weight. "The attempt and not the deed confounds us."
