beamblanck
- Feb 26, 2009
- 7
Hi all,
I need some help about the command "end lenght offset"
PROBLEM 1
As you can see in the attachment i've a a problem witha column.
I've a column (a simple pipe) 4000mm high linked between two profile 500 mm high. I need to follow the distance between the neutral axis of the profile that is 4500 mm so when i model the wireframe structure i have to stretch my columnf of 500 mm (250 mm each part), altought the "free high" (i don't know in english, sorry) is always 4000mm.
This is a case where i've to use the end lenght offset command? and again...theoretically, modelling all the connection in the wireframe mode the "end lenght offset" command should be used everywhere?
PROBLEM2
my column is a pipe of several diameters, why if i divide the column in many parts and i check the columns with the eurocode 3 i obtain different ratios in every frame.
in practice: if a use an entire singular fram i obtain a ratio lesser than 1, if i divide the same frame in two, three different frame i obtain that some part had a ratio major than 1 so...not acceptable.
I hope you'll understand
many many thanks to all the people of the forum
Alberto.
PROBLEM 1
PROBLEM2
Alberto.
