Help! Need single row tapers
sprintcar
763
0
0
Help!
Purchasing gave up and came to Engineering for assistance (ha!) so I'm asking you guys for help!
We're looking for 100 pc's each Timken (or equal) taper bearings.
P/N's
Cone 72225C
single cup 72487
or (50 ea) TDO Cup 72488D
ID Bore 2.25"
OD 4.875
K factor 0.79
I'm in contact with the major bearing companies, but I'm looking for ANY Distributor/Dealer or excess inventory (any quantity)
Need is immediate, PO will be issued right away
Thanks!!
Keep the wheels on the ground
Bob
There is a company in Augusta Ga, actually Grovetown, called Bearing Distributors. They are great to work with and have done miracles for me. If they can't find the bearings then probably nobody can.
Thanks Willdo - I had gotten some of a different size from them and they did manage to find some of these.
FYI - I did learn that the "China Syndrome" seems to have sucked the OEM pipeline dry, but virtually all sizes are available thru distributors. We got a bunch from Canada where they don't have an inventory problem.
Bob
