HELP!! - Pro/E 2001 (UNIX) Core Dump
ella0509
66
Hello everyone.
I am doing some renderings for our R&D dept. and have come across a problem I thought you might be of some help with.
I have imported a .jpg image into my workspace. This image is then attached to the top of a disc. Worked fine all day on Friday, managed some nice renderings etc. Closed down, opened up today, everytime I try to open that part (in shaded mode) or any assembly using that part, Pro/E shuts down and creates a dump file. If I switch-off "enable textures" in the model display settings I can open it and work with it with no problems. Is this a known bug, is there a workaround??
Thanks for your help,
Lee
Lee,
What build/date code are you using? I would also check PTC's website for any reported bugs.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
You can try the config option
display wireframe
in config.pro
see if that helps. otherwise try to find an older prt.? version before the .jpg was added.
Michael
Hi all, thanks for your response.
I seem to have fixed the problem, but I'm not sure which change I made sorted it out.
1. Changed the .jpg extension to .tx3.
2. Created unique folder for this and other images in my UNIX home directory.
3. Put unique texture_search_path into my config.pro that points to the folder in 2 above.
Now opens, revolves etc without problem.
Lee
