shacked
- Aug 6, 2007
- 182
Architect wants to use a proprietary guardrail system for residential. I downloaded their calculations but something just doesn't make sense to me when I review their calculations. I have attached them with red clouded areas that are pertinent.
Analyzed is Risa with a 200# pt load at node N20 in the Z direction they get a 295ft-lb moment at the base node N16. If this is correct then that is a big difference between the typical single post static analysis, with no load sharing.
Also, on page 9, their base plate calculation is kind of confusing. They are resolzing the 295 ft-lb moment at base plate/post into a point load(I guess a 3" moment arm) then multiplying that force by 1/2" to get a moment of 708 in-lb??? This doesn't make sense. If the moment arm is 3" and the width of the square base plate is 3.5", then what is the 1/2" moment arm?
I would think that the base plate should resist the full 295 ft-lb being developed between all 4 bolts.
Thanks for your input
