Help surface
UserCFAO
44
Help me! Nx5
Hi!
I would like to rebuild a new surface
- Delete the blue radius
- Offset of the green area of 4 mm
- rebuild surfaces as the snapshot
thank you !
sorry for my english
I hope that I have interpreted the question correctly. The problem seems to be associated mostly with the fact that the blade section is of poorer quality. There are a few segments of surface that lack any real continuity and which I have simply patched over to create a workable solution. Any additional curves created non associatively that you may wonder about are simply extracted Iso-parametric curves.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
 http://files.engineering.com/getfile.aspx?folder=73ea3e9d-c744-486a-8cec-d6d64416b463&file=help_huds.rar
Exactly what i wanted thanks Hudson
another question. is it possible extracted Iso-parametric curves (associatively) ?
As far as I know not.
Best Regards
Hudson
www.jamb.com.au
