Help understanding-->fieldOutputs['S'].values has two different results for each element
beick3
I'm trying to report the von Mises stress at specific location on my model (3D-shells with S4R elements). To that end, I partitioned the locations of interest into small squares, and seeded the edges of those partitions such that there will always be only one element in the partition. Then, I assign the faces of the partitions into individual geometry sets (thus creating elements sets as well). I run the analysis, and extract the stress with the following python script (not showing the import commands, etc., to save space)
sets=['S02-01','S02-14','S02-15','S02-16','S02-17','S02-44'] #project specific location names
lastFrame = odb.steps[steps[0]].frames[-1]
stress=lastFrame.fieldOutputs['S']
for setNumber in range(0,len(sets)):
--location=odb.rootAssembly.elementSets[sets[setNumber]]
--locationStress=stress.getSubset(region=location)
--locationValues=locationStress.values
--for v in locationValues:
-----print sets[setNumber], v.elementLabel v.mises
the results printed are as follows (first column is the set ID, second column element Label, third column Stress of interest)
ElementSet, ElementID, VonMises Stress
S02-01, 3, 2.59445095062256
S02-01, 3, 2.74841952323914
S02-14, 1983, 6.80963182449341
S02-14, 1983, 6.42978477478027
S02-15, 5, 3.05168008804321
S02-15, 5, 3.25940418243408
S02-16, 111, 2.47030067443848
S02-16, 111, 2.63920927047729
S02-17, 1776, 2.61065101623535
S02-17, 1776, 2.23680400848389
S02-44, 11, 2.12529110908508
S02-44, 11, 2.19687485694885
As seen, there are two different values for the von Mises stress at each element. The first value reported is what is seen using the 'Query-probe value' tool in the GUI. Anyone know what the second value is reporting? There is only one step in this model.
After investigating further, there are two separate fieldOutput['S'].values objects... that is, there is a fieldOutput['S'].value[0] and fieldOutput['S'].value[1]
Any insight is greatly appreciated.
S4R has one integration point and by default (Simpson integration) 5 section points through thickness. By default A/Standard writes the results of the 2 outer section points into the .odb.
Ahh! That makes sense. I think either of those outputs are acceptable for my purpose (mesh convergence study). For future reference, are you aware of how to force output of all five section points? I can't find an option in "Field Output Requests".
Thanks again!
You can get output at all points with:
*ELEMENT OUTPUT, ELSET=SetName, VARIABLE=ALL
1,2,3,4,5
I see... if I'm correct, I think this will do the same in the GUI, then, right?
That'd be my guess, but I generally don't spend much time in the GUI except for results visualization/post-processing. You can verify in the .inp after writing it from the GUI though.
Yeah, it looks like it did it. Here's an image for anyone else's future reference.
Thanks for your help!
Yes, it's the same option.
In /CAE it is easy to have a preview at the input file. Model -> Edit Keywords
