fel3
- Jul 9, 2001
- 915
We have a project in San Diego County, California, that includes about 800 ft of 11 ft x 4 ft (inside) precast concrete box for a storm drain. Except for a little bit at each end, the entire alignment is in a residential street (the ends are "in dirt"). Cover ranges from about 18 inches to 6 feet. The standard we are using for this item is ASTM C1577, "Standard Specification for Precast Reinforced Concrete Monolithic Box Sections for Culverts, Storm Drains, and Sewer Designed According to AASTHO LRFD."
Although I had a significant role during the design phase, most of the design work itself was performed by our engineering team in San Diego (I'm in Fresno). I served mostly as a technical resource/mentor/QA-QC engineer/project humorist (every project needs a humorist, especially this one....for reasons I won't go into here). The project is now in the very beginning of the construction phase and our San Diego team is handling construction phase services and I am on call to help, much like before but more limited. At this point, they are mostly dealing with submittals and RFIs.
Now, with this preamble out of the way....
One of the project engineers asked me yesterday to take a look at the submittal for the precast concrete box. The submittal includes a copy of ASTM C1577-14 (I have already questioned why not a more recent version because there are NINE newer ones available).
As I read through ASTM C1577-14, I don't see anything that requires or even implies a seismic design approach. My question to those in the group who have experience with ASTM C1577, is there anything in this standard, especially in Table X1.1, that covers seismic? What am I missing?
When I designed buried cast-in-place vaults in the remote past, I always included a lateral seismic force to the walls. I did a Google search on this subject and found several published papers regarding seismic forces on buried structures and several relevant Eng-Tips threads. Everyone agrees that seismic forces need to be considered....because they exist. Seems simple enough.
On the other hand, the State of Washington DOT limits the requirement for applying seismic forces to buried spans > 20 ft: and Is this perhaps a reasonable practice for small structures?
Thanks in advance for your help.
--Winston S. Churchill
