Help with charging a rechargable Li-Ion Battery Pack
xMeckii
Student
Aug 28, 2022
1
Hello, just a quick question if someone could help with an answer. I am in need of charging a 18650 Li-Ion battery pack, but short notice and needed before a hobby charger would arrive for me to use. So I am looking at using a variable power supply to do so but wanted guidance before doing this as I wouldnt want to overcharge or use the wrong voltages/currents.
The pack I am using is a 18650 quad battery, 14.8V 2.6Ah, 38.48Wh rechargable battery pack. I know that the usual voltage for Li-Ion batteries are 4.2V and 1A if I am correct to charge a cell, followed by stopping when the current reaches 1 tenth of an amp (100mA), but would this be the case for a battery pack as all the videos I see are for just one battery instead of multiple.
Any advice would be appreciated as I need the pack charged within the next day or two.
The following image is the only type of data I could find on RS components for the battery pack i purchased.
 https://files.engineering.com/getfile.aspx?folder=f3934e16-daea-410a-ba5e-c396b1442618&file=Screenshot_20220829-015945_OneDrive.jpg
I think there are two things to monitor that will go wrong otherwise.
The first is that setting a constant-current value means 100% having to watch the voltage. Even a short time above 4.2V per cell at constant current will likely start a fire.
The second, the 4.2V constant voltage phase is useful for the topping off; avoiding that topping charge might be enough to avoid problems at the loss of a small capacity loss.
Can the power supply be set to shut down at 4.1V ? A constant current of 1A seems OK; but 100% that 4.2V cutoff isn't negotiable, so stay back from it and accept a lowered charge until a proper charger arrives.
If you cannot guarantee that cutoff, find a fire-proof container for the battery while it charges.
In this video on li-polymer cells, they manage a fire, and they said with the charger it was tough, because the charger has timers and current detection and voltage detection; if you only have current control and the power supply keeps ramping up the voltage above the 4.2V cutoff then be prepared for:
