Help with definition.
isolating distance
the clearance between open contacts meeting the safety requirements specified for disconnectors
Found on isolating distance
the shortest distance between the fuse-base contacts or any conductive parts connected thereto, measured on a fuse with the fuse-link or fuse-carrier removed
Found on
Red is closer. Blue is between phases. Please note that neither sketch is very precise. The isolating distance would need to be measured when open, and the blue line looks more like a center to center distance than the minimum distance between live parts.
