Help with hoist application needed 1
tmckeown
11
First time posting here. This is a great forum. I've learned a lot from just reading it all day.
I've been assigned to make a cable hoist for our company. I finished the first batch of them and they turned out pretty well, but I'm having a few problems that I could use some expertise on. First, I'll give you the parts that I'm using, so you get a better picture of what's going on.
1) ABB ACS350 vector drive
2) Brother mid series 1HP gearmotor (1268 in-lbs @45RPM)
3) Dynapar encoder (on drum shaft for positioning)
4) 8" Diameter grooved drum
5) Custom controller (we made it)
The spec I needed to meet was:
Must be able to accurately position a 300# load
Must be able to move it from zero speed to 100 feet per minute
Must fit into a specific lighting truss
Description:
A user sends a command from a lighting console (DMX) to the controller. The controller keeps track of positioning as well as translating the desired speed and destination info from the lighting console. The controller sends the drive speed (0-5 volts) and direction info. The controller also creates the ramps up to speed, down to stop and it sets the brake when at the destination. The drive obviously controls the motor. The drive is set to have the fastest ramp .1 sec. This is so the controller can handle the ramping. We are running the drive in vector torque mode, though we have done tests in vector speed mode as well. The motor has a brake. Both the controller and the drive have to tell the brake to be released before it gets released. When the drum is moving, the controller counts the encoder pulses to determine its position. When its within X steps from the destination, it start a ramp down of the control voltage feeding the drive. When the destination is reached, we set the brake and remove voltage to the drive as well as telling it to not move either up or down.
For the most part, it works well, though we're not completely satisfied with the performance. I'm hoping someone might be able to fill in the blanks of our knowledge and help us get the project completed.
We chose the Brother gearmotor due to it's size 15"H and it's weight 44#. We chose the ABB drive simply because a sales rep said it would do what we needed. On an 8" drum, the motor is able to give us 317# of torque. We pushed the max frequency of the drive to 69HZ, which lets us hit the desired 100' per minute. We can get very good repeatability on positioning.
So, what's the problem?
We are having trouble controlling the motor at very slow speeds. We find that we are not able to release the brake immediately upon start of a move, or it will drop the load. So, to get around that, we have tried two things. (not simultaneously)
1) We set the drive to release the brake once it's reached a certain speed.
2) We send the drive a minimal control voltage and keep it there for a few seconds before releasing the brake.
In both cases, it does prevent the load from falling, but the initial move is a bit of a jump. If we lower either of those two values, the load drops. We could almost live with the jump, but we see another related problem when we try to do very short 1"-2" moves. When we do a very short move, occasionally after the move is completed and the controller has turn on the brake, the drive won't shut off. We can hear it pulsing; trying to move. We checked the current to the motor, and the drive is sending the max current we allowed (6.2A). If we then try to do another move in the opposite direction, the drive still retains control and tries to move the motor in the previous direction. When that happens, the drive keeps moving the motor until it reaches the torque that is set by our control voltage and then quickly starts moving in the correct direction. Pretty odd eh? For the longest time, we though the controller had a software bug. After days of testing, we found that we can reproduce this glitch at will.
We have spoken to the drive engineers at ABB. They tell us it is because we are not allowing the drive to ramp down before we set the brake. We don't want the drive to do a ramp. We are creating the ramp in the controller and sending the control voltage to the drive. If we allow the drive to handle the ramp, there is no way for us to stop at the correct destination. The encoder for positioning connects to our controller.
This brings up a number of questions:
1) Is a servo motor a better option for a cable hoist? They seem very expensive and much larger than the Brother motor.
2) Should we change the Brother motor to one with an encoder? The brother has no place to mount an encoder. The brake is on the end of the motor and there is only about 1/4" of shaft sticking out from there, but it's all under the fan housing. Maybe someone knows of an encoder we could add?
3) Should we change the drive? Maybe there is one that could give us full torque holding without a motor encoder.
4) Have we reached the limit of what we can do? Do we need to de-rate the hoist to a lower lifting weight, so we can move slower and avoid these problems?
I know I've probably created even more questions with my questions. Thanks for the help.
Tom
niallnz,
I had thought about that, but the Z channel is only once per revolution. I need a minimum of 60 for positioning. Good idea though. I'm also ordering a 1024PPR encoder for the motor. We think we have figured out a way to add it to the back end of the motor. It will take some work, but might do the trick.
Gunnar,
yep, I'll be reading a lot. I don't want any problems. They told me they do have some fairly well versed guys in the US office. I'll be talking with them once we get the drive and do some preliminary reading.
Thanks again everyone for all the help.
Gunnar,
Thanks for the recommendation of the OptiDrive Plus 3G. We picked one up. We also bought an encoder module for the ABB ACS350 drive we are currently using. Wow! So far, there is absolutely no comparison in performance. The ODP can start from a dead stop and hold the hoist there at our maximum weight. That's very impressive. We're talking with ABB's engineers now. It's hard to belive that a sensorless vector drive can beat out a closed loop vector drive in our hoist application. I really wanted to go with the ABB, but everyone who's seen the two picks th ODP every time.
For those interested in what the differences are that we are seeing; we find at very slow speeds (<10HZ), the ACS350 seems to pulse the load, most likely in an effort to control it. Maybe we aren't using an encoder with a high enough resolution? We have a 1000ppr encoder on the motor shaft now. In addition to smoothness at low speeds, the ACS350 is quite a bit noisier. It never bothered us till we heard how nearly silent the ODP was. Both drives are set for 16KHZ.
The only issue for us with the ODP is the size. We have to re-engineer the chassis it goes in, due to it's larger size. We also notice a weird rattling sound at some point during deceleration. I've got a call into Bardac to find out if we need to skip frequencies to cure that. I know I'm starting to sound like a Invertek commercial, but I'm extremely impressed with the performance. I was completely prepared to go with a closed loop solution, which I know should be better. In or experience, the ODP was simply better.
Thanks again,
It sounds like there may be a tuning problem with the ABB drive. There was another post a while back with a closed loop vector drive on an elevator making a lot of noise and I recall it was something in the tuning. I don't recall the make of the drive though.
Thanks Lionel,
We're talking with ABB now. Maybe they will have some ideas how we can better tune it. We've spent a few weeks with it and haven't solved it.
I am really pleased that you actually tested it. I know the designer personally and I will show him your reaction. He will not be surprised.
Gunnar Englund
Gunnar - I bet he's a really sharp guy too. A lot of people think that vector control is easy but few can actually get it right.
The only time I've really played with an ABB VFD I was using a regen as the load at 60hz. I had to switch the ABB to V/hz control to get it to hold a steady speed and load otherwise it kept very slowly speeding up or slowing down.
Yes Lionel - but not only sharp. He is also using a somewhat differening motor model. In essence, he is using the calculated air gap EMF and its integral to calculate actual rotor speed and position. The method has several patents and results in a very crisp step response as well as an ability to control speed a lot better than standard algorithms do.
The work started when Ragnar Jönsson (the inventor) was head of development of anti air-craft gun control and wanted to get rid of the hydraulic systems. He studied servo motors and induction motors and realized that the sluggish performance in induction motors was largely because of stator winding R and X. He therefore developed a motor model where these quantities are completely eliminated (well, identified and nulled out).
There is a complete description in the patents and in the book "Control of Electrical Drives" by werner Leonhard (no, not Leonard - that was another guy).
Gunnar Englund
