Help with rainfall term
atrizzy
362
Hi all,
I have a client that is specifying for a design that we use a value of '24 hr mean annual rainfall.'
This is a value being used in conjunction with a catastrophic event, and is intended to be less intensive than a typical 'extreme' type of rainfall.
However, any dataset (IDF curves, etc) I look at requires that we define a return period. The client's design criteria documentation does not expand on the meaning of '24 hr mean annual rainfall.'
Any idea what that could mean?
It's the average 24-hour rainfall total for whatever period storm is required. It sound like they are looking at a 1-year storm. What do the design requirements from the local authorities say?
I found a govt guideline for stormwater design indicating that MAR (mean annual rainfall) should correspond roughly to a storm of 2.33 yr return period.
This seems reasonable enough, and I think is a good enough reference to approach my client with. Unfortunately, this client does not require adherence to local authorities... otherwise, the criteria might be simpler.
2.33 yr return periods sounds about right for a 24 hrs storm, however that is a wholely inadequate rainfall to determine anything more than a rain ticket printing order.
It is completely insufficient to avoid drain backup and serious ponding problems on flat roofs, for example, if that's the issue here. A 1h rain can equal 60% of the 24h total.
Thanks 1503, understood. This rain is meant to coincide with, and mildly exacerbate, a very rare and catastrophic event.
For that you need to look at the return frequencies. That's your indicator for the degree of severity of a catastrophic events.
Houston example latest NOAA data
Thanks so much 1503, very helpful.
Depending on what the project is, you may want to be certain on the frequency of the storm event. As indicated by 1503-44, there are a lot of different frequency storm event (well, not really, but that is how it's typically how it is stated) for storm event. A lot of regulations for a catastrophic rain event will typically be the 25-year, 24-hr storm event. Now, this doesn't mean that the storm will only occur once every 25 years, it means that the probability of the storm event happening every year is 4%= 4/100 = 1/25.
Additionally, since this is in a hurricane prone area, there may be requirements to use data that is more stringent than normally required (e.g., using the 50 or 100 year storm vs. the 25 year storm).
Have you asked the client for clarification since this is not a typical design criteria?
