Hi Folks
I urgently need to replace a current 14 tooth pinion with a 17 tooth one with no change to the 52 tooth mating gear.
I tried reading up some stuff and though I could decipher the basis for the specs and translate that to the 17 tooth pinion required, but realized that I have quite some ways to go. I hope I can get through with it this one time with your help.
Current Pinion
Z=14, OD = 20, Pitch Diameter=17.5, Module =1.25,
Pr. Angle = 20
Mating Gear (Will remain unchanged)
Z=52, OD = 67.50, Pitch Diameter = 65
Detailed Specifications
Pinion Gear
Basic Rack:
Addendum = 1.0447 x m; 1.0224 x m
Dedendum = 1.2053 x m 1.2376 x m
Tooth Thickness= 1.5708 x m 1.5708 x m
Base Diameter=16.4446 61.0800
Correction factor = - 0.0446 -0.0424
Norm. Tooth Thickness = 1.9229 1.9249
Base Tangent Length = 5.742 - 0.034 21.170 – 0.042
No of teeth spanned = 2 6
Dim over 2 pins = (20.827 -0.074) (68.451 -0.110
Pin Diameter = 2.300 2.300
Tooth Quality: DIN 58405 Class 9
Composite Method
Composite Error = (0.050) (0.063)
Tooth to Tooth error = (0.018) (0.022)
Run-out at Tip = 0.042 0.053
Tooth Alignment Error0.018 0.016
Tip Diameter utilizable=19.722 62.885
Root Dia Utilizable=16.467 62.805
Centre Distance 41.25
New Pinion will have Z = 17 & Center Distance = 43.125
I need detailed specs for the new pinion.
Thank you very much
JohnLouis
