Help with Visulization view cuts
fruton
56
Hi all,
I have solid 3D deformable models in contact with analytical rigid surfaces. When I try to visualise the model (i.e. Von Mises Stress) through a view cut it turn hollow in the middle. I get the following message..
"Vuew cuts through swept analytical rigid surfaces are not supported and will be ignored", but these are 3D deformable views.
Can anyone help?
Ignore it. It's just saying you can't cut an analytical rigid surface. The results on the 3D deformable body will be cut, however.
Tara
select the two options to the left för the specified cutting plane
Show Name Model
v Z-plane v v
/Stig
