Indumathis
Chemical
hi,
we use Tangential Flow filtration for the seperation of cell debris and in the past few runs we have had problmes with teh downward trendingof the permeate flow untill the last runit was almos zero. We did a routine maintanance by replacing all teh gaskets etc. but couldnto find any problem. We use Pall filters adn all the runs the integrty tests for bothpost and pre runs were good. The only thing is that we don't have readings for perssure sinc ethe operators did not note it down for the runs. Would there be a problem with the way they maintained the perssures on the feed, retantate and permeate. The TMP was maintained the same though.
The last run when there was 0 permeate flwo, the flow picked up when we reduced th eretentae flow and we don't know why such a behaviuor.
Please advise.
Please advise.
