Hi everyone,
I have a part that was manufactured improperly, and I need to fix it as quickly as possible. Basically, we had a through drilled through our part that was 1.875" in diameter, and then a from the center of this part out in two directions, the hole was enlarged to 1.90". So basically, starting at one end, you have a Ø1.875" hole for 2.5", then for the next 10" the hole is Ø1.90", then the last 2.5" of the part the hole goes back down to Ø1.875".
Basically the holes on the outside are still Ø1.875", but the inner part of the hole is < Ø1.875, instead of being Ø1.90". This part was going to be machined by our parent company that has the capacity to make this kind of cut, but we do not,so we need to find a supplier who is capable of making this cut for us. Do anyone out there know of a company that could make this kind of cut? The closer to Ontario, Canada the better...
Thanks for any suggestions,
Tom
Tom
