HETVAL Subroutine compilation error
Check the log file for errors. That’s the code from documentation example, right ? There might be a problem with Abaqus and compiler linking if it doesn’t work.
Yeah, it turned out to be an issue with the install folder in Abaqus, the simulation runs if started on a different machine. Thank you!
