KevinNZ
- Jun 12, 2003
- 861
Can anyone please suggest a detail to reduce the vibration of the divider plate in the end cap of a two pass HEX? See attached.
This plate in vibrating and cracking the welds where it is attached to the head, Also moves across the contact point at the tube sheet and stuffs the gasket.
We are thinking of installing support stay rods between the plate and the head.
There is around a 50C temperature difference between the flows.
