Hi Can someone help in translating
Ehaviv
Computer
IL
Hi
Can someone help in translating this code to vb
Thank you ln advanced.
Copyright (c) 1999 Unigraphics Solutions, Inc.
Unpublished - All Rights Reserved
The following UG/Open API program asks you for a part number,
and displays the configured revision of the specified part. It prints out
a list of all the configuration rules available on your system and tells
you your current configuration rule. Finally, it attempts to set your
configuration rule to "Working".
#include <stdio.h>
#include <stdlib.h>
#include <uf_ugmgr.h>
#include <uf.h>
#define CHECK( func_ ) { int ifail_ = 0; char message[133]; ifail_ = (func_); if ( ifail_ != 0 ) { UF_get_fail_message( ifail_, message ); printf("ERROR: %s returned from %s\n", message, # func_); return ifail_; } }
int main(int argc, char *argv[])
int ifail = 0;
int num_rules;
char** config_rules;
char current_rule[UF_UGMGR_NAME_SIZE+1];
int i;
UF_UGMGR_tag_t part_tag;
UF_UGMGR_tag_t config_part_rev_tag;
char part_number[UF_UGMGR_NAME_SIZE+1];
char rev_id[UF_UGMGR_NAME_SIZE+1];
ifail = UF_UGMGR_initialize(argc,(const char**)argv);
if (ifail != 0)
printf("ERROR: Failed to initialize with error code %d",
ifail);
exit(1);
printf("Enter part number :\n");
scanf("%s", part_number );
CHECK( UF_UGMGR_list_config_rules( &num_rules, &config_rules ) );
printf("AVAILABLE CONFIGURATION RULES:\n\n");
for ( i = 0; i < num_rules; i++ )
printf("%s\n", config_rules);
CHECK( UF_UGMGR_ask_config_rule( current_rule ) );
printf("\nCURRENT CONFIGURATION RULE: %s\n", current_rule );
CHECK( UF_UGMGR_ask_part_tag( part_number, &part_tag ) );
CHECK( UF_UGMGR_ask_configured_rev( part_tag, &config_part_rev_tag ) );
CHECK( UF_UGMGR_ask_part_revision_id( config_part_rev_tag, rev_id ) );
printf("\nCONFIGURED REVISION OF PART %s: %s\n", part_number,
rev_id );
CHECK( UF_UGMGR_set_config_rule( "Working" ) );
UF_UGMGR_terminate();
return 0;
Code:
#include <stdio.h>
#include <stdlib.h>
#include <uf.h>
  int             ifail = 0;
  int             num_rules;
  int             i;
  if (ifail != 0)
 ifail);
    exit(1);
    printf("%s\n", config_rules[i]);
  rev_id );
  return 0;
i
