Hi there: I am kind of new desig
electron
PR
Hi there:
I am kind of new designing forms in Visual Basic 6. I have design some forms in a 1024 by 768 pixels when the program is run in a 800 by 600 pixel screen area part of the form falls outside the screen. Is there a routine to change the program screen properties to what ever the computer that the program is run the screen area is set? I have looked into the windows API functions (I think there is the solution) but no answer found yet. Any help will be very appreciated.
Rafael Rafael
The best way is to start designing in 800 x 600. This is the most used, especially by 14 inch monitors. Use TrueType fonts like Arial. Test your application at 640 x 480 before you deploy it.
Regards Steven van Els
SAvanEls@cq-link.sr
I found this while perusing one of my favorite sites for VB Info
Hope it helps.
HOWTO: Create a Resolution-Independent Form
The information in this article applies to:
Microsoft Visual Basic Learning Edition for Windows, versions 5.0, 6.0
Microsoft Visual Basic Professional Edition for Windows, versions 5.0, 6.0
Microsoft Visual Basic Enterprise Edition for Windows, versions 5.0, 6.0
Microsoft Visual Basic Standard Edition, 32-bit only, for Windows, version 4.0
Microsoft Visual Basic Professional Edition, 16-bit only, for Windows, version 4.0
Microsoft Visual Basic Professional Edition, 32-bit, for Windows, version 4.0
Microsoft Visual Basic Enterprise Edition, 16-bit, for Windows, version 4.0
Microsoft Visual Basic Enterprise Edition, 32-bit, for Windows, version 4.0
SUMMARY
If a Form takes up most of the screen at 640 x 480 (VGA) resolution, it only takes up a small portion of the screen at 1600 x 1200. Normally, this is exactly what you want to happen, but some circumstances arise where you want a Form to retain the same proportional size and position regardless of screen resolution. This article discusses a simple way to accomplish this for an Single Document Interface (SDI) application. It does not address special considerations for Multiple Document Interface (MDI) applications.
MORE INFORMATION
When designing Forms to be resized at run time, keep the following in mind:
When designing Forms, it is best to design them for the lowest screen resolution you expect users to run. Even using the technique outlined here, it is best to stay with this rule because Forms resize better going to higher resolutions than they do going to lower ones.
Use TrueType Fonts because they are scalable. Also, try to use Fonts that will be available on the user's system. Otherwise, a substituted Font may not scale properly.
Because resizing may not always be exact, especially with Fonts, make the controls a little larger than the minimum necessary. Also, try to leave a little space between controls.
Some controls, like CheckBoxes and Option buttons, do not resize, and some controls may require special handling. For example, the Height property of ComboBoxes is read-only at run-time, but changing the font size adjusts the Height. Other controls may not have a FontSize property and need some other property set to make FontSize appear correctly.
Step-by-Step Example
Change the video resolution to 800 x 600.
Start a new project in Visual Basic. Form1 is created by default.
Add a Label, a CommandButton, and any other types of controls you would like to test.
Copy the following code into the Form's module:
Option Explicit
Dim MyForm As FRMSIZE
Dim DesignX As Integer
Dim DesignY As Integer
Private Sub Form_Load()
Dim ScaleFactorX As Single, ScaleFactorY As Single ' Scaling factors
' Size of Form in Pixels at design resolution
DesignX = 800
DesignY = 600
RePosForm = True ' Flag for positioning Form
DoResize = False ' Flag for Resize Event
' Set up the screen values
Xtwips = Screen.TwipsPerPixelX
Ytwips = Screen.TwipsPerPixelY
Ypixels = Screen.Height / Ytwips ' Y Pixel Resolution
Xpixels = Screen.Width / Xtwips ' X Pixel Resolution
' Determine scaling factors
ScaleFactorX = (Xpixels / DesignX)
ScaleFactorY = (Ypixels / DesignY)
ScaleMode = 1 ' twips
'Exit Sub ' uncomment to see how Form1 looks without resizing
Resize_For_Resolution ScaleFactorX, ScaleFactorY, Me
Label1.Caption = "Current resolution is " & Str$(Xpixels) + _
" by " + Str$(Ypixels)
MyForm.Height = Me.Height ' Remember the current size
MyForm.Width = Me.Width
End Sub
Private Sub Form_Resize()
If Not DoResize Then ' To avoid infinite loop
DoResize = True
Exit Sub
End If
RePosForm = False
ScaleFactorX = Me.Width / MyForm.Width ' How much change?
ScaleFactorY = Me.Height / MyForm.Height
End Sub
Private Sub Command1_Click()
DesignX = Xpixels
DesignY = Ypixels
RePosForm = True
DoResize = False
End Sub
Add a Module from the Project menu and paste in the following code:
Public Xtwips As Integer, Ytwips As Integer
Public Xpixels As Integer, Ypixels As Integer
Type FRMSIZE
Height As Long
Width As Long
End Type
Public RePosForm As Boolean
Public DoResize As Boolean
Sub Resize_For_Resolution(ByVal SFX As Single, _
ByVal SFY As Single, MyForm As Form)
Dim I As Integer
Dim SFFont As Single
SFFont = (SFX + SFY) / 2 ' average scale
' Size the Controls for the new resolution
On Error Resume Next ' for read-only or nonexistent properties
With MyForm
For I = 0 To .Count - 1
If TypeOf .Controls(I) Is ComboBox Then ' cannot change Height
.Controls(I).Left = .Controls(I).Left * SFX
.Controls(I).Top = .Controls(I).Top * SFY
.Controls(I).Width = .Controls(I).Width * SFX
Else
.Controls(I).Move .Controls(I).Left * SFX, _
.Controls(I).Top * SFY, _
.Controls(I).Width * SFX, _
.Controls(I).Height * SFY
End If
' Be sure to resize and reposition before changing the FontSize
.Controls(I).FontSize = .Controls(I).FontSize * SFFont
Next I
If RePosForm Then
' Now size the Form
.Move .Left * SFX, .Top * SFY, .Width * SFX, .Height * SFY
End If
End With
End Sub
Try running this under different screen resolutions and the Form should take up the same desktop area and retain its look and screen position. You may notice that your design resizes better when changing to a higher resolution than it does when changing to a lower one. You can also use the Mouse to Resize the Form and it will re-scale automatically. Finally, if you change video resolution while the Form is open, you can click on Command1 and it adjusts for the new resolution.
Hi There:
Thanks for your help. It has been very helpful
Appreciated.
Rafael Rafael
