Hiding columns in a BOM
mrkoko
40
Does anyone know of a way to hide columns in a BOM so that they do not appear when printed but do appear when you save the BOM out to an excel or a csv file. I am on SW 2009 sp2
Thanks,
You can create two copies of BOM Table (one for export and one for printing) and customize them. Next hide/show one of them in FM Tree depending on the situation (printing or exporting)
Artem Taturevich
CSWP
ah, thanks ! I really had no idea on that one. A friend though they remember being able to do it with a $PRP$ or something to that effect in the header row of the BOM but I can't find any documents to support that, nor can I get it to work.
Can you move the non-printing columns to the right? If so, then set a Print Area (in Excel) for only the desired left-columns.
Otherwise you'll need a macro (actually probably an add-in if you want to use this across many files).
Ken
As Artem said previously, just create 2-bom tables. No need to hide either table. For the exported table just drag it off of the drawing sheet and it will not print.
Andrew
