HIDING DATUMS in Catia 4
designmr
230
Anyone know how to HIDE completely the DATUMS and keeps them hiding?
I was sent a file (.product) with hundreds of parts, I want to just hide ALL the DATUM PANELS at once.
The version I am using is CATIA, Version 5, rev 9. Seems you can hide the datums, and save the file. Once you call it up again, the datum are BACK again, same with contraints.
Yeah, Solid7, you understand exactly....
If I had another job, I would tell you....
designmr
Thanks for the script updates,,,,
Solid7
The No show script was fine, just worth mentioning in case others try to copy and have a problem that the line:-
selection1.Search "CATPrtSearch.Plane.Visibility=Invisible,all"
Needs Capital "V" in visible in order to work, at least thats what I found, as follows-
selection1.Search "CATPrtSearch.Plane.Visibility=InVisible,all"
Thanks again guys.....
