WE MONITOR VIBRATION ON THE DIE BLOCK OF A ROTARY PUNCH MACHINE PUNCHING .015IN STEEL AT 800/SEC.ACCL. HAS 35KHZ RESONANCE AND MONITOR IS FFT WITH UPTO 20KHZ BW,UPTO 32OO BINS AND TO 51.2KHZ SAMPLING RATE.PUNCH VELOCITY IS SUCH THAT SHEARING EDGE THEORITICALLY PASSES THRU STEEL IN .0000102 SECONDS.THE TIME TRACE IS CLASSIC IMPACT TRAIN. THE SPECTRUM HOWEVER IS TOTALLY DOMINATED BY HIGH AMPLITUDE HARMONICS USUALLY ABOVE 9KHZ.AMPLITUDES ARE 3 TO 10 TIMES FUNDAMENTAL IF IT CAN BE FOUND. VARIATIONS IN PUNCH FREQUENCY HAVE NOT BEEN FOUND.IT IS UNDERSTOOD THAT HARMONICS SHOULD EXIST BUT NOT WHY THE AMPLITUDES ARE SO HIGH RELATIVE TO FUNDAMENTAL.
