I'm looking for a relief valve that will handle 150-200 gpm and maintain a low pressure (10-20 psi or even lower if possible). Ideally the valve would have the capability of controlling the relief setting electronically (or with a pilot pressure that could be controlled electronically). The ideal relief setting range would be around 5 psi to 250 psi. This is for a test stand application where we currently have a valve capable of limiting the pressure to about 75 psi. We have a new use for the stand though that needs even lower pressures. I've looked around for a new relief, but so far I haven't found anything that looks like it will work. Any ideas? Thanks in advance.
