Hello…Experts !! Happy New Year to all of you !!
LVGO –Light Vaccum gas oil is one of the product from Vacuum crude distillation column , high Total chloride especially inorganic chloride is reported , while checking at overhead receiver boot water chloride it remains only 1 or 2 ppm , while LVGO chloride data shows total chloride 15 ppm ,20 ppm some times 23 ppm , it varies from 5 ppm to 25 ppm ; out of which organic chloride is very less say , e.g. out of 20 ppm , 16 ppm is inorganic and rest is organic , desalter efficiency remains ~ 98 % ,LVGO draw temperature is 130 to 140 C; LVGO Return temp. is ~ 40 C ; NH4Cl Desublimation temp. delta online monitoring is there but it shows more than 20 C delta difference, lab analysis shows no presence of Fe,Zn,Al metals & absence of amine,ammonia chloride or not even Na,Ca ; It sounds to be HCl.Caustic dosing in upstream crude unit is ~ 200 to 300 lph.One thing which was observed that , whenever NH3 demands goes up in VDU Column ovhd (Dosing as per Overhead reciver boot water pH), chloride in LVGO goes down ;
What are the potential cause of this chloride ? It is very critical point of concern because this LVGO goes to VGO hydrotreater and it can cause sever corrosion in the downstream.
Thanks in advance to all of you.
