Bobfromoh
- Sep 9, 2002
- 157
Not sure where to post this but I'll start here? This is actually a question concerning hobby items: neon lights on a toy HO scale train display with a power supply that causes high pitched annoying noise. I have four picture displays connected to one power supply. It doesn't matter though, one or four displays cause the same problem. I am older so I don't hear the high pitched sound. But anyone younger complains that it is annoying.
I tried hiding the power supply under the platform and it helps, but not enough. I called the manufacturer and they said there is nothing I can do about it. The power supply is about 3" x 4" x 3/4" thick. So the question is, is there someway to enclose the power supply to greatly reduce or eliminate the noise. Also, it get fairly warm so heat dissipation is a problem also.
