BexBex1000
- Jul 14, 2006
- 10
Hi Everyone.
I am currently building stainless steel pumps which are used in high pressure (up to 200 bar) applications and mounted on environments such as Oil platforms in the oceans. At current the main fasteners I am using are high tensile steel such as 12.9 grade. The pump is then painted with maritime paint usually to customer specifications. The problem is that the environment is getting through the paint and attacking the bolts and I fear is weakening these bolts. Can anybody recommend to me any grade of material for the bolts which give me better resistance to the environment but at the same maintain the tensile strength? I have thought of materials such as Inconel 718 but this is very expensive and I was hoping for some other suggestions?
Kind regards
Anthony
Kind regards
Anthony
