I need to select suitable bolting material for bonnet studs / Nuts of a High Pressure valve. Following are the specification:
Valve body / Bonnet material : ASTM A182 Grade F91
Body design Condition: Class 2500
Maximum Operating pressure: 220 barg
Maximum Working temperature: 610°C
Application: Condensate, Steam
I need to know if it is okay to use UNS N07718 (ASTM B637) bolting with F91 valve body at the specified design conditions. Would there be any issues like galling, galvanic corrosion etc.
Do we have any other high strength bolting material options for use with F91 valve bodies?
Thanks in advance.
Thanks in advance.
