DevonH
Petroleum
- Aug 30, 2006
- 7
I was wondering if anybody is aware of an engineered high pressure clear pipe option that is rated higher than typical clear PVC pipe/fittings or full-view sight flow indicators. A portion of the pipe length can be metal, and then if there is a clear section within it, that is what is desired. The higher the pressure the better, but I will consider all ideas out there to see what are the best options.
The full-view, sight flow indicators that I've seen are only rated to about 150 psi at 2" diameter.
I am basically wondering if there is technology similar to a full-view sight flow indicator (or something different) but with higher pressure rating.
Thank you!
Thank you!
