High Pressure Water Pump
fcxdfm
44
I am looking for a pump manufacturer, who can make high pressure water pump with 60,000 psi for jet cutting. The motor needs to be hydraulic driven.
Thanks for help!
Thanks, unclesyd.
I don't quite understand how this hydraulic intensifier works...Are you aware of any web linkage with information how it works?
Thanks again.
FYI: Intensification is when you take, say 2000psi (of liquid), and run it into a ram which is pushing on another smaller piston. The pressure of the fluid behind the smaller piston will have been 'intensified' by the ratio of their piston areas.
Last week I was shocked to see this occur when pressure was run into a double acting cylinder the pressure on the other side of the ram was far higher than the pressure supplied by the hydraulic pumps. Really confused me for a minute.
Keith Cress
Flamin Systems, Inc.-
Unclesyd,
Your information is very helpful. Thank you so much!
