High speed bearing help. Sizing Question.
  • Thread starter Thread starter -
  • Start date Start date
Guest
Where is a good source for high speed ceramic bearing (100,000 rpm). I found some sites but it seems like they only small sizes. Can you help me?
Thank you.
Do you have any more specifics (size, load, etc.) for the application?
Try KOYO bearings in Japan.
They had a 115,000 rpm ceramic bearing when lightly loaded and using a oil lube not grease.
Check them out. I am sure that they are on the WEB somewhere.
Edson Campos
edsoncampos@earthlink.net
FAG also has a large selection of hybrid ceramic bearings.
