NIDinc
- Jun 22, 2011
- 27
We currently manufacture a specialized, compact 2 hp, 230 VAC three phase induction motor. It is designed for variable speeds up to 250 Hz, or about 15,000 rpm. It runs at about 2.5 amps, no load at this speed and requires only about 15psi air to operate under a working load of about 5.5 amps (full load amps: 6.4).
We modified the motor to run at about 24,000 rpm by changing the windings and wire appropriately and increasing the Hz to 400. Mechanically it can handle the speed.
The only problem seems to be that the efficiency has dropped off dramatically and the motor is generating too much heat at the windings and rotor.
We're not motor engineers and the consultant who designed our original motor years ago is no longer available. Any thoughts, tips and input for ways to improve the efficiency and lower the temps is much appreciated.
Thanks, JS
Thanks, JS
