phuduhudu2
- Jul 17, 2018
- 2
I am proposing to cast in a concrete padstone at both ends of a 5m long brick wall. Between the two I will run a 7mm high strength wire as used in prestressed concrete within a raked out bed joint in the brick on either side. I need this to take a lateral load from the padstone at one end of the wall to the other. My question is, how can I anchor the wire into the concrete padstone at either end? I assume welding to high strength wire is not possible. I know for post tensioning they use anchor blocks but these normally cater for multiple strands coming into a single block.
