High temperature liquid to air heat exchanger
Adrian2
303
Hi Folks;
I need some help locating a supplier for a liquid to air heat exchanger intended to be used in a stack with 850 degree C airflow.
Attempting to heat up liquid using waste heat
Are there commercial heat exchanger that do this or would this be a custom design ?
Many Thanks in advance
Adrian Dunevein
AAA Drafting Services
Your temperature is much higher than I have experienced, but the application is similar to a boiler economizer. You could check with the larger boiler manufacturers such as Babcock & Wilcox.
